A1035 sc350
  • petrus
    • 155
    A1035 sc350
    anybody knows the description f the SC350 error code on A1035?
    I dont have this explaination in the service manual>
  • djq2
    • Jun 2008
    • 25
    sc 350 relates to
    the I.D. sensor.. possibly dirty needs to be cleaned and initialized... or the developer needs replacement due to low density pattern on the drum,
    hope ths help's
    • etsmultan
      • Apr 2007
      • 131
      u have to reset the copier and after entering service mode enter 5801#then execute memory then on/off it will ok,otherwise it may be u hv to replace developer
      • Ricoh-ono
        • 338
        I have never had to do a memory clear (sp-5801) in order to correct a SC-350 error code. A memory clear should be one of the last things to try.
        Do what you can, with what you have, where you are. ~Theodore Roosevelt
        • tonerjock
          sc 350 is an id sensor error you can check this in sp mode 3103
          and it will tell what the values are. Id sesor v should be 4v.It could be as simple as running id sensor voltage adjustment sp 3001-02 which automatically adjust id volt. Your problem could be a dirty id sensor however unlikely Drum cleaning problem would give poor id sensor voltage. cleaning dev roller and changing developer and drum would fix your problem.
          Good luck
          • Voltage
            • Jul 2008
            • 282
