SC325 with MPC305
  • hanspeter75
    • Mar 2010
    • 37
    SC325 with MPC305
    Does anyone know this problem when starting up the device? The motor for the color stations does not rotate ... even without Dev-units.
    Thank You
  • Zeldaman
    • Mar 2011
    • 946
    • hanspeter75
      • Mar 2010
      • 37
      Re: SC325 with MPC305
      both .... changed no success. look further
      • Zaxxon
        • 608
        I've changed a zillion Controllers on these, don't know if it can generate the error you describe.
        Please start you post with brand, model, problem.
        • hanspeter75
          • Mar 2010
          • 37
          Hi
          If it helps someone, I finally have the complete gear unit replaced with success
          Many screws......a lot of time .....
          greeting
          • bob marley
            • Jan 2012
            • 1339
            Hi
            greeting
            Thanx 4 the infor
            Live for yourself and you will live in vain. Live for others, and you will live again
            • Debs1964
              • Oct 2010
              • 1693
              Hi
              greeting
              It's a fun job isn't it!!
              There are 10 types of people in this world, those who understand binary maths and those who don't
              • copier tech
                • 8144
                Wow that's a big strip down, in a school too! how long did it take you Debs!?
                • Debs1964
                  • Oct 2010
                  • 1693
                  You really don't want to know LOL
                  It took significantly longer than it should have as I was only replacing the toner hoppers (ONLY!!!), but the very last screw dropped into the drive unit. After I rebuilt it I was getting the message to reset all PCU's, so this was day 2, I replaced the drive unit. I reckon I could do it in under 3 hours now.
                  This school were incredible, they moved the 2 PCs that usually sit on the table next to the copier to give me room, and kept me supplied with drinks, and a chocolate bar
                  • copier tech
                    • 8144
                    A nice/understanding customer make this job easier, I've got a few of this 305's in tiny pre school offices, not even room to clear a jam, I dread having to strip one down at these locations!
                    I have got a fuser drive unit to replace as you may have seen, looking at your pictures it looks like it is still in your machine, I hope I don't have to strip it down that much do I!?
                    • Debs1964
                      • Oct 2010
                      • 1693
                      I've not done a fuser drive unit yet, I hope it's not too bad for you. The main issue with these is to have plenty of space and not be rushed for time, I don't panic on them now, done toner hoppers on 3 machines now
