Firmware
  • trc
    • Jan 2007
    • 95
    Firmware
  • trc
    • Jan 2007
    • 95
    Re: Firmware
    Sorry for the mistake, the MP 6001 with the Blown Finisher Board i is a SR 4030 finisher.....(not SR 4050)
      • 37490
      Re: Firmware
      If everything else is the same on the boards, you will need to replace the EEPROM.
      • trc
        • Jan 2007
        • 95
          • 37490
          Re: Firmware
          In that case, you will have to replace the board.
          • donholl
            • Apr 2015
            • 3
            Re: Firmware
            I am positive these boards/ finishers are not interchangeable, mechanically they are the same finisher; however, they changed from the e-prom style firmware in the SR 970, to the SD card update for firmware with the SR 4030, even in the SR 4030 you have to pay close attention to what style control board is in the finisher, as Ricoh changed vendors mid production and there are different firmware for each style board. Hope this helps
            • Iowatech
              Not a service manager
              • 3930
              Re: Firmware
              Yikes, I forgot all about the board change! Thanks for reminding me.
