SL-M3870FD - Faded stripe
    replied
    Re: SL-M3870FD - Faded stripe
    Congratulations on your success! =^..^=
  • yoeljacobsen
    replied
    Take a look at the developing roller. Is there a 5.6cm bare area on the developing roller?
    Yes! - It wasn't easy to observe due to the roller's location in the toner cartridge.
    A toner replacement solved the problem.
    Thank you.
    replied
    Take a look at the developing roller. Is there a 5.6mm bare area on the developing roller?
    Common on monocomponent developing devices, the machine may not detect that the toner cartridge is mostly empty.
    Toner cartridge yields are typically based on 4% fill area per page (for 10K). If your enduser printed/copied 6.5% fill area (for 6.5K) the cartridge is empty. =^..^=
  • yoeljacobsen
    started a topic SL-M3870FD - Faded stripe
    Hello,
    I have the following problem. An SL-M3870FD MFP. The counter shows ~72K pages.
    The attached PDF file is a scan of two prints:
    - page 1: a solid black rectangle
    - page 2: a page filled with characters
    Some observations:
    • There is a faded (are with last intensity) stripe of 5.6CM.
    • The intensity loss is less severe in the top 4CM of the page.
    • The toner is a genuine Samsung installed about 18 months ago. It printed ~6500 pages (of 10K).
    • The transfer roller and fuser roller look good from a quick inspection.
    • I see no clear obstacle/paper pieces in the laser window.
    Any idea what to look for?
    Thanks.
