samsung clx 3175 paper jam 1
  • printerman47
    what is the correct part number for the photo interrupter for the exit.
    we bought one from our wholesaler, and it appears tiny bit larger than the OEM.
    0604-001393 was the part number.
    • 23008
    Re: samsung clx 3175 paper jam 1
    You've got the right number. the actual Photointerrupter has changed several times in the search for a better component. Don't be concerned if it looks a little different. IIRC the original sensor has a white connector. The most recent style has a black connector. =^..^=
    • printerman47
      sweet! thanks for the educate.
      • printerman47
        thanks for your help. we have to the OEM and replacement. the difference appears a black hood that covers over the top of the connector. It wont fit into the hole because of the black hood of 3175, we are going to dremel off the black hood (CAREFULLY)
          • 23008
          If you had removed one of the screws retaining the ext assembly you could have raised the exit assy ~25mm, and installed the PI without modification. But you got it in there.
          That's all that counts. =^..^=
          • printerman47
            ah, just a bit..that all it takes. lol
            will check out the ext assy closer. thanks for your help.
            • familydean
              I just replaced this sensor and reassembled, but now the printer is printing an all black page. I guess good news is there's no paper jam Any thoughts? Thank you in advance for your help.
              • JustManuals
                • Jan 2006
                • 9838
                Paul@justmanuals.com
                  • 23008
                  I'm going to go out on a limb and guess that you meant blank page not black page. Try this:
                  Blank prints & copies during service call. One of two plastic 40mm long levers has come detached from the base of the front door, and has fallen in the paper tray. This lever operates the laser shutter. Reinstall or replace the plastic lever.
                  • familydean
                    No really it's a "black" page like the page is full with black toner. Like it's not reading the image or something.
                      • 23008
                      Does that include copies, prints, scans, internal reports?
                      If it affects only scans and copies, I have a vague recollection of getting black scans when I forgot to connect a 6-pin ribbon cable from the scanner to the controller board.
