no paper pickup
  • COPYDOCAZ
    • Mar 2015
    • 110
    [Jamming] no paper pickup
    AL 1631 ....this is strange I can't seem to make the feed tires turn, even when I mannualy engage the pf solonoid I replaced the drive assembly but still no drive. the gears are turning and I diassembled and lubed the spring clutch.
  • faxman28
    • 435
    Re: no paper pickup
    if gear turns but feed tire doesn't turn then spring clutch hub is broken , the part of the spring clutch that
    has the gear (similar to this part NGERH1132FCZZ-ar-168) connected to the feed roller shaft with a roll pin , the inside hub with roll pin cut out breaks away from gear, have seen this happen on several older sharp copiers ar151, ar168, ar162 and the like. also if there is a lot of copies the spring and hub may just be worn out and are slipping.
    • NeoMatrix
      Senior Tech.
      • 3513
      Re: no paper pickup
      There has been a few post about Sharp paper feed problems over the years.
      You may like to search CTN for "clutch arbor"
      Try this Link :
      http://www.copytechnet.com/forums/sh...aper-tray.html
      Otherwise Search here:
      Copytechnet Forum Search - Via Google
