sharp sf 2030 - heavy background
  • mzr
    Hey
    i have a sharp SF2030
    i serviced the mirrors , corona wires , drum unit and any part that need
    and i replaced the Developer and inserted new toner to machine
    At first copy i saw a dirty sheet , so i tried to solve the problem with the directions "Adjustment when replacing the developer" inside the Service Manual , such as acceptable values
    but there was some differences between the machine and the SM.
    However i tried to solve the problem with codes but i couldn't.
    i think there is no problem with drum and blade because when i remove th drum unit and rotates drum , Blade clean the drum as well
    i`m so confused
    somebody help me
