AR-m277 print issues
  • acsolutions
    • Jun 2010
    • 519
    [Misc] AR-m277 print issues
    Hello, the arm277 will print small sets of documents or sometimes wont print at all! on the main board there is a rj45 port can I use that to print? The manual shows that I need a pcl expansion board and Nic options. I was just wondering if I can print to that port? The machine has the expansion I was wondering if I can print to that port as well. Thanks
  • bilyahn
    • Dec 2006
    • 1455
    Re: AR-m277 print issues
    If you have the NIC showing then you can print. You can verify this with sim 22-10. I always reset the NIC when I put it in a new location. Had too many problems in the past where this wound up being the fix!
    Good luck
    Bil
