MX-3100n, Maintenance Required DK....
+ More Options
Posts
  • Oystercopy
    • Oct 2009
    • 623
    Hey guys..
    I have a new customer who's got this message on the front panel. It appears to be needing a Black Drum Unit, but I'm not sure if anything else should be done? Does the drum reset the indication, or do I have to go into simulation to do that?
    Thanks in advance,
    OC
  • driving lots of miles
    • Jun 2016
    • 399
    Re: MX-3100n, Maintenance Required DK....
    I would replace the drum and the main charger kit at the same time. You will need to go into the sims to reset both these items.
    • mttech
      • Mar 2014
      • 127
      There may be other items needed as well. The black developer is timed at 100K pages for replacement with the drum and maint kit. Also a filter and a couple of cleaners. Depending on the cycle of the copier other items are scheduled for replacement at 200K and 300K pages. There is a button on top right of display that reads MFP status. Touch that and it may give you more information, or print out a sim 22-6 and you can see current page counts for maint items.
