List of Sim 55-3
  • boutn
    • Jun 2016
    • 547
    List of Sim 55-3
    Hello,
    does anyone have a list of the settings you can change with SIM 55-3 or SIM 55-1?
    We have some settings we got from Sharp, but the refuse to give us a full list...
  • guitar9199
    • Sep 2016
    • 1100
    Re: List of Sim 55-3
    55-1 Used to set the specifications of the engine
    control operations. (SOFT SW)
    55-2 Used to set the specifications of the scanner
    55-3 Used to set the specifications of the
    controller operations. (SOFT SW)
    What reason would you have to change these settings anyway?
    • boutn
      • Jun 2016
      • 547
      We change a few things when starting up new machines...
      Change % of toner left to steps of 5 in stead of 25 sent by snmp
      laser shutdown after job so the machine makes less noise
      enable traysettings on webpage on the new models
      show job time left
      and so on...
      So a full list of the soft swiches would be helpfull.
      Or even a partial one...
      Probably there are things in there that can be very usefull.
      • Robert Hindmoor
        • Jun 2018
        • 5
        Hi Boutn,
        Is it possible to get the switch that allows us to enable tray settings in the webpage? this would save us so much time.
        Regards,
        Rob
        • boutn
          • Jun 2016
          • 547
          Originally posted by Robert Hindmoor
          Hi Boutn,
          Regards,
          Rob
          sim55-03 sw48 set all to 0
          • Robert Hindmoor
            • Jun 2018
            • 5
            Thanks for sending this over to us.
            Any other words of wisdom you can pass across would be greatly appreciated.
            • Luke123
              • Nov 2017
              • 22
              There is not list of all the engine soft switch setting. For security reasons Sharp will not give this information out. They only give out soft switch info if it will help the machine. If you want to change the toner notifications from 25% to 5%, that is done in sim. 26-69.
