transfer roller Cleaning?
  • axyun
    • Aug 2007
    • 1323
    If a transfer roller needs cleaning is a dry lint free cloth the only remedy ? Can alcohol be used or something milder? Thsi is of course when a new one is not readily available. Frank/ActionP
  • Tech2002
    • Aug 2008
    • 334
    If you use a liquid of any kind, dry time is an issue. Any liquid or solvent is going to brake down fiber of roller. I have tried cleaning similar Transfer Rollers with Chemical - not a good thing.
    • axyun
      • Aug 2007
      • 1323
      Most replies have said no liquids , especially solvents. And most use dry cloth or vaccumm (some with a small brush attachment. Thank you. Frank
        • 23008
        All the manuals say dry dust-free cloth. You might as well wish it were clean. That just doesn't work.
        I've had good luck with mild ammonia-free glass cleaner, just try not to soak it, and let it dry. Don't scrub. Wipe charge rollers with a long continuous stroke end-to-end, and keep going around until it's clean (3 or 4 times around depending on how dirty it is).
        Never use alcohol. It will definitely damage the surface. =^..^=
