Office 365 TLS 1.2 and Sharp MFP
  • remixz95
    • May 2025
    Hi,
    I have read on technet that Microsoft will drop support for TLS 1.0 and 1.1 in Office 365. But does it apply to smtp traffic through office 365?
    What i understand will Sharp only release firmware for newer models, like MX-2640 and newer.
    We have a lot of customers that uses office 365 and have older machines...
  • HikingAK
    • Sep 2017
    • 12
    Re: Office 365 TLS 1.2 and Sharp MFP
    Originally posted by remixz95
    Hi,
    Here's the Sharp Tech Tip:
    TT-051418_1.pdf
    • havokprod
      • Oct 2012
      • 156
      Yep the sky falling for me...... 3 calls today. 1 MX-B402SC, 1 MX-M503N, and 1 MX-M623N. Told the customers to setup smtp relay via gmail till the firmware is available.
      • OlliK1969
        • Nov 2016
        • 309
        MX-M503N available
        MX-B382SC available
        MX-M623N available on Sharp FTP Server
        • tonasis
          • Oct 2015
          • 10
          • guitar9199
            • Sep 2016
            • 1099
            Make sure you're using the correct port. (587) If that's being blocked, you could try 2525.
            • boutn
              • Jun 2016
              • 537
              Anyone else having trouble with smtp via Office365 since yesterday?
              Seems like a general problem...we have a lot of clients calling in...
              • mansart
                • 852
                • remixz95
                  We have had a lot of client calling yesterday and today about scanning problem with Office 365. It's not related to the TLS firmware update.
                  We have solved all Office 365 problems of putting the replay adress within < > and change the port to 587.
                  • boutn
                    • Jun 2016
                    • 537
                    FW solves the problem for the newer machines.
                    Older machines like the MX5112 will not work with the brackets...but i found a solution!
                    If you go to "Security Settings" - "SSLsettings" - Level of Encryption: set to HIGH (standard is low)
                    This fixed the problem for the MX5112 in our shop.
                    Still have to test with other "older" machines, but hoping this will work.
