Sharp MX 3640N Void areas intermittent
  • Ben Around
    replied
    Re: Sharp MX 3640N Void areas intermittent
    Originally posted by Demon33
    I had this problem once & it was the bushing/spring on the first transfert roller. The bushing is held by 2 plastic clips and one was broken.
    Try changing the primary belt assembly for a test if possible
    Thanks, I'll look at that. I had a brand new primary transfer belt (frontier series) drop the bushings on a color roller last month. They weren't broke, they just fell out and were sitting on the developer unit. I just put them back in and it's been fine.
  • Ben Around
    replied
    Does it happen on just black? From the looks of it I don't think it has anything to do with low ac wall voltage as the rest of the print looks good. It is not repeating which I would think that would eliminate developing unit. It just seems to be in that particular spot. I'm with Mansart on this one and Phil B. Try fresh paper and look at primary transfer belt for indents of some sort. The last picture has me puzzled as it looks as though something is sorting out, but would not put money on it. Try fresh paper then transfer belt.
    Yes, only on black (as far as I can tell). I ran sky shots of each color and could not reproduce the problem.
    I've had paper bite me in the behind a few times over the years. So yeah, I wish I would have swapped the paper out, just to eliminate the possibility. But I didn't, so shame on me.
    I put a loaner on site and I have the machine in the shop. So I will be looking at it more closely today. It also has an oil resistant squeaky noise in the Doc feeder, so I get rip that apart too.
    Thank you everyone for taking the time to respond with suggestions.
  • Demon33
    replied
  • ZOOTECH
    replied
    It's been awhile, but I remember that a piece of lint or similar material on the main charge or grid would cause the same symptom.
  • copiertec
    replied
    replied
    Originally posted by Ben Around
    ??? really???
    Toner cartridges are inserted and at lease 75% full
    The paper is 20 bright white hammermill 500 per ream
    And the paper is not damp, the relative humidity level in the office is 74.285%
    Did that help narrow the possibilities down a little.
    The meter is 20,000 B/W, 12,000 color.
    Ben .. if you are a tech going on a call.. wouldn't you think those bits of info are vital?
    75% humidity isn't that low.. most paper makers and machine makers would like to see humidity around 50% so that it IMHO too high. Paper may not FEEL damp but can cause voids.
    you never gave the values in OP..
  • Ben Around
    replied
    why is it people ask for help and always leave out info like:
    supplies status
    weight of media
    is paper damp?
    ??? really???
    replied
    Thanks for the reply. I'll look into that.
    supplies status
    weight of media
    is paper damp?
  • Ben Around
    replied
    Originally posted by mansart
    I've seen this but can't find my notes on this problem. If memory serves me correct it is something to do with primary xfer.
  • mansart
    replied
  • Ben Around
    started a topic Sharp MX 3640N Void areas intermittent
    Has anyone encountered intermittent void areas on a Sharp MX2640N, MX3140N, MX3640n series machines.
    While running (copy mode) 5 pages at a time 2 out of 5 copies will have the void ares.
    I tried swapping the black drum unit, it had no effect. Also checked laser unit connections and re-seated the memory. Wall voltage read 120v with a multi-meter.
    And I checked the laser glass carefully to make sure there was no foreign objects.
    I'm thinking there may be a problem with the line voltage being electrically noisy. Or possible an issue with the laser unit or main board.
    MX3640N Void areas.pdfMX3640N Void areas.pdf
    Sample attached.
    The void areas are intermittent and random, but look similar and occur roughly in the same area of the page.
    8.5 x 11 feed long edge first, copy mode from glass. 2 out of 5 test pages will have the voids.
    Any thoughts are appreciated.
