MX2640 - E7-03 Error
  • Leebs14
    • Feb 2014
    • 457
    [Error Code] MX2640 - E7-03 Error
    I have a recurring issue with e 2640 that it randomly throws a E7-03 code, the customer switches off/on and the machine is again fine for days/weeks before doing it again. Knowing there are issues with SD cards i have been there and replaced the SD Card and updated the firmware to the latest level. I did a 62-02 (I think) and that ran ok and showed no errors but I am thinking maybe the HDD is starting to fail?
    AM I correct?
  • tek tevee
    • Jan 2020
    • 6
    Re: MX2640 - E7-03 Error
    HDD 100%
    • copiertec
      • Jan 2016
      • 2172
      Seems you have covered your bases, I second the HDD as your next logical solution.
      • jon jennings
        • Aug 2011
        • 51
        AM I correct?
        The SD card is the most likely suspect. They start going bad and throw E7-03 and U2 codes.
        • repn1999
          • May 2010
          • 310
          I recommend replacing both the SD card and hard drive together. We make our own sd cards using high quality sd cards which dont fail and use 500gb wd blue 2.5 hard drives as replacement drives. havent had any issues with this solution and have done it probably 25 plus times.
          • gs461167
            • Oct 2021
            • 1
            where would i be able to purchase these items or get someone to fix my copier problems?
            • copiertec
              • Jan 2016
              • 2172
              Pick up the phone, spend some money and call a copier repair company to fix your issues.
