Sharp MX4100 MX4101
  • buzz
    • Aug 2013
    • 288
    Sharp MX4100 MX4101
    Light washed out areas, black only.
    CMY OK
    See test sheets for sample
    Swapped cyan and blk drum same, no change.
    Dev mag brush looks even (not tiger striping)
    I'm leaning towards Main Charge Receptacle but wanted your thoughts on this old box
    Thanks!
  • rspicer
    • Oct 2015
    • 97
    Re: Sharp MX4100 MX4101
    I would also check primary transfer.
    • mojorolla
      The Wolf
      • 2626
      Pull the IT belt out and remove the belt. Look at the FTR (first transfer rollers). If memory serves correctly, these PM kits came with the four rolls under the belt. Ensure the rear wall and belt contacts are free of toner. Also make sure LSU glass are clean and shutter is working.
      • spanky
        • Sep 2012
        • 468
        Run a black skyshot and stop the copier during this process.
        Are the light areas showing on the drum?
        If not are they showing on the transfer?
        If not that leaves the second transfer.
        • Hansen88
          • 1068
          You can swap the black drum unit with one of the color ones and see if the problem moves to the color you swapped it with.
          • OlliK1969
            • Nov 2016
            • 311
            Hi
            secondary transfer belt in the door
            • chubblies
              • Jun 2011
              • 155
              Remove laser, there is a solenoid in the laser cavity that operates the shutter that gets covered in toner. Either leave the shutter off or remove and clean the solenoid
              • miller01123@gmail.com
                • Jun 2019
                • 55
                Try the clutches on the main drive that lift the T1 rollers.
                • buzz
                  • Aug 2013
                  • 288
                  Thank you, yes I did swap the drums and the problem did not follow the black drum. Thanks.
                  • buzz
                    • Aug 2013
                    • 288
                    We had another copier to swap out the whole laser unit and the problem was still there.
                    • buzz
                      • Aug 2013
                      • 288
                      It ended up being the whole Primary Transfer Assembly that fixed the issue, thanks!
