sharp mx3140n
  • bruce 49dcs
    • Jan 2017
    • 140
    sharp mx3140n
    hello
    I do mostly toshiba but have been a tech since 1986
    im working on an mx3140 that had lines in yellow and cyan so i replaced both drum kits no problem now the color is a little off so i wanted to do a color calibration
    on toshiba its simple you just choose calibration in admin user mode it prints a chart you put it on the glass and hit start and your done
    well with the 3140 I cant find a chart i try sim 63-3 46-74 plus others and nothing it even says enter sim sub number and press start ofcourse it doesnt say start it says color and mono
    I need a definate sequence and method to calibrate the color please help this copier is making me look like an idiot
    thanks as usual
    bruce
  • tmw
    • Dec 2013
    • 222
    Re: sharp mx3140n
    When you get to the sim, in the lower right corner has an execute icon. When that is pressed, the chart will print out. Then you put the light side with the thin line to the left side so it starts reading there. Then hit execute again. A couple charts print out. When it's done, you press ok. Sometimes some machines ask to use 11 x 17, I don't know why. Sim 46-24 & 54 also has an auto calibration too, if you wanted to go that far.
    • leo34staffs
      copierman
      • Aug 2007
      • 500
      Re: sharp mx3140n
      Originally posted by bruce 49dcs
      hello
      thanks as usual
      bruce
      You press the Colour or mono buttons, they act as the start button, also i would do a full calibration. 44-2, 44-27, 44-6, 44-26, 50-22 (Turning the laser screws if out) then a 46-74, also remember to clean ID sensors before doing any process control sims.
      Networking skills are advantageous but use of a 3m vacuum cleaner is essential
      • bruce 49dcs
        • Jan 2017
        • 140
        Re: sharp mx3140n
        thanks ill post the results
        • bruce 49dcs
          • Jan 2017
          • 140
          Re: sharp mx3140n
          well i did the 44 sims and when i went to do 46-74 it cam up in red saying enter sim sub code and it wouldnt take it so i rebooted the machine and bam the color was perfect
          I dont know why it wouldnt accept 46-74 or print a chart but it is working
          • brokey
            • Oct 2011
            • 19
            Re: sharp mx3140n
            After doing the other sims you have to reboot the mfp before you can do 46-74
            • bruce 49dcs
              • Jan 2017
              • 140
              Re: sharp mx3140n
              I see that tidbit was not mentioned in the book but it is working now so i think ill leave it alone thanks for all the help
              • leo34staffs
                copierman
                • Aug 2007
                • 500
                Re: sharp mx3140n
                Your welcome!
