Mx-M264 Blurry Copies
  • Squiggy
    • Jan 2020
    • 39
    I have a MX-264N that when you make a copy, either through the document feeder or off the glass, they come out blurry (out of focus) and slightly shifted. Internal prints and when the customer prints to it come out fine.
    Any suggestions would be appreciated.
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 695
    What troubleshooting measures have you done?
    • Squiggy
      • Jan 2020
      • 39
      Cleaned the mirrors,lens and CCD
      • harps05
        Field Service Engineer
        • Mar 2012
        • 112
        Being that the image is out of focus AND slightly shifted, it sounds like the lense unit has shifted. It only takes the slightest of movement to have the whole image go pear shaped. Has the machine suffered any knocks or anyone tampered with it, because these things don't suddenly happen.
        • ihatefinishers13
          • Feb 2020
          • 695
          Thinking back, I've had two 2640 series machines that started doing wonky things with copies/scans, ended up having to replace the CCD. It was showing weird colored lines, blowing the image up a little and shifting it about an inch upwards.. Had the exact problem within days of each other, two different territories, and have never had it otherwise.
          • Squiggy
            • Jan 2020
            • 39
            Thanks ihatefinishers13, that sounds similar to we have going on. We're debating between the CCD & scan pwb
            • JLSam
              • Jun 2015
              • 605
              Originally posted by ihatefinishers13
              replace the CCD. It was showing weird colored lines, blowing the image up a little and shifting it about an inch upwards...
              Second this.
              • Squiggy
                • Jan 2020
                • 39
                Thanks everyone, The CCD indeed fixed this problem. A few days later I had the same exact issue with a MX2616 and Immediately replaced the CCD.
                • ihatefinishers13
                  • Feb 2020
                  • 695
                  So weird that it happens within days of each other like mine!
