Re: SHARP DX-2000U - F2-40 Error, EE-EL error
Thank you for your input on this. however, I ran sim 25-01 multiple times without the toners installed then proceeded to sim 25-02. EE-EL won't go away. how much is the developer for this machine ?
You might get lucky but the easiest and expensive way is to replace the developer in all of your DV units and start over. Then run perform your calibration per the SM.
Good luck
BilLeave a comment:
I think that your problem is that the toners where installed before running Crop 25-02 now you have to much toner in the Developer 25-02 sets the reference level try running 25-01 a few times without the toner installed then try running 25-02 still with the toners removed EE-EL can also mean to little toner or the developer and toner have separated in transport running 25-01 will mix the toner and developer again then running 25-02 will set the refence level again at worst case you may have to dump the dev in the affected colors replace it start again but sometimes you can be lucky.
Hope you get sorted.Leave a comment:
Hello Colleagues,
I have a brand-new SHARP DX-2000U copier that has never printer anything since we bought it. it all started when it arrived and I had to set up the machine; ADF connectors were plugged and installed, the base was plugged and installed, and toner cartridges were installed too. upon powering the machine, I got an F2-40 error message. I quickly turned off the machine and I remember not pouring the developer(MX-36FV-SA for m,c,y and MX-36FV-BA for black) into the developing unit. had to install the developers accordingly then powered the machine again. the error won't go away. Made a little research online and then came across a few threads where they talked about running SIM 25-02 to calibrate the developers. I ran SIM 25-02 but forgot to remove the toner cartridges. now am getting an EE-EL on k,c,m, and 0 for y after calibration.
This machine is driving me crazy and I will appreciate it if someone can assist me to figure out what exactly is the problem and how to fix it.
Thank
