ARM-351n printring problem
  • vlad_robas
    • Oct 2006
    • 225
    I have this machine instaled on a customer site and a month ago becouse he didn't pay ... i took the machine back to shop where we did a revizion and now the money problem resolved and the customer took back the machine but it print like in the attachement. Normaly is connected trugh network but i tryed to USB and he does the same thing. Diferent version's of driver's.
  • OMD-227
    Looks like Hexidecimal Dump Mode is turned on..... could be wrong, but gee it looks like it.
    • vlad_robas
      • Oct 2006
      • 225
      Right, as always.
      Thank you again.
        • 22594
        Cool! Along the right column you can see the actual printer control language text of the print job (PCL XL). Is this Sharp's idea of a data capture? =^..^=
        • redserv
          • May 2010
          • 307
          wow i have that exact same problem setting up ARM451N on a network at the moment, so what was the fix? to get rid of the garbage?
          • rayjeek
            • Jun 2010
            • 239
            The problem looks much like a corruptted print driver. what I can suggest is to uninstalled the print driver, update the firmware on the MFD to the very latest, download the latest print driver from Sharp's website and give a go.
            All the best of luck
            • redserv
              • May 2010
              • 307
              think the problem was solved, Hexidecimal Dump Mode is turned on.how do you turn it off on MX-M451n?
              • OMD-227
                Its usually in Printer settings mode inside system settings (admin). Its usually just a tick-box.
                • vlad_robas
                  • Oct 2006
                  • 225
                  I will continue here...
                  On another machine somethime's it does print one side ok and another is without contrast, i wasn't there when it happend so don't know if it was first side or second. What should i search for?
                  • rayjeek
                    • Jun 2010
                    • 239
                    IN ORDER TO TURN OFF THE HEXADECIMAL DUMP MODE, FOLLOW THE STEPS:
                    1-SYSTEM SETTINGS or CUSTOM SETTINGS(with old MFDs)
                    2-LOG IN AS ADMINISTRATOR (00000)
                    3-PRINTER SETTINGS
                    4-INTERFACE SETTINGS
                    5-'HEXADECIMAL DUMP MODE' IS THE FIRST LINE
                    6-UNTICK THE BOX TO TURN IT OFF
                    CAUTION: PLEASE DO NOT REMOVE TICK MARKS FROM:
                    ENABLE USB PORT & ENABLE NETWORK PORT
                    • redserv
                      • May 2010
                      • 307
                      ah ok, thanks alot for the info rayjeek hope you;re not mad :P
                      • clevernet
                        打乱码
                        换块多功能板就可以解决问题啦
                        • redserv
                          • May 2010
                          • 307
                          ok guys thanks alot for all the help, i Disabled HEXADECIMAL DUMP MODE and it was right on the money, anyone care to explain what is
                          HEXADECIMAL DUMP MODE and why did it come enabled on the mfp?
                          • OMD-227
                            When Hexadecimal Dump Mode is activated , the print data is printed as hexadecimal byte values rather than characters. Control commands are also printed as hex values.
                            This allows you to inspect what control and print characters are being sent to the printer, which is a useful debugging facility for the more difficult printing problems. Its usually an option used by programmers as well, to fine-tune any special commands they have written into a specific client program.
                            Its usually not on by default. Its something that you enable/disable yourself.
