SHARP MX-M350U CQ SPF only
  • J_Lee
    • 111
    WHen you copy through the spf leaves a thick black bar across the bottom of the page, well pretty much half the page.. When you copy on glass it's fine and when you print internally it looks fine.. I believe it's just a setting but not sure which one HELP!
    [IMG]file:///C:/Users/JLee/AppData/Local/Temp/moz-screenshot-2.png[/IMG]copier trouble.jpgmail.google.com.jpg
  • OMD-227
    Are you sure the main scan glass & slit glass are seated correctly, and the doc feeder is level?
    That image with the 'sawtooth' effect is usually given due to overhead fluro lighting near the machine. If the doc feeder is not level or scan glass is not level, light can be entering at the left hand side of the scanner.
    • J_Lee
      • 111
      It's level, but now I'm getting an E6-11 code to go with it
      • ZOOTECH
        Senior member of CRS
        • 3375
        E6-11 is a CSI shading trouble; check and clean the white reference plate, check the harness and make sure all LEDS are coming on and the glass cover is not full of dust inside. It could also be the doc feeder is not parallel to the scanner.
        • OMD-227
          Thats what I'm thinking....... especially with that effect on the page.
            • 23008
            If it's just copies you may want to check the alignment of the SPF with the slit glass. It is a common mistake to try to adjust out original skew by changing the angle of the SPF. All this does is mis-align the white plate with the slit glass. =^..^=
