Toner consuming on AR M550
  • costa.mk
    I have a very big consuming of toner on this AR-M550 28-42k and never more with toner AR621T which should rich 83K with 5%. This customer use this machine only like copier no prints at all. Somethmes there is more then 5% coverage but not significant. I try ADJ 9 Adjusting the copied image quality but with very light copy I gat +5K at most.
    New OPC & New Developer is instaled and corect sim 25-2 with open door was done.
    Any Idea???
    Thanks in advance
  • OMD-227
    When you run dev adjust, was the toner cartridge installed? That can definitely affect the dev value over the life of the dev.
    Make sure the firmware is up to date, at least these shown.....
    Then make these changes to improve low & halftone density...
    *** The firmware must be right before doing this OK.
    Toner use also varies depending on machine location, temperature, humidity, long vs short copy/print runs, high rotation values of drum/dev (must be reset in 24-11 upon replacement too), firmware levels & good operation of drum sensor.
    • costa.mk
      The toner cartridge was installed but we sealed toner supply holes on dev unit so concetration of toner in dev was unchenged during instalation.
      I did not check firmware but on next wisit I will and I will make sugested changes.
      All couters were cleared by the book.
      Thanks wazza, I will let you know as soon as I make changes.
      Best Regards
      By the way can anybody tell me from experiance how many copies with one AR621T on AR-M550 can be made in practice
      • OMD-227
        How long is a piece of string??
          • 23008
          I like that! =^..^=
