Sharp fax boards - dialing prefix for MX350 and AR-M2{357}7 machines
  • kmyer
    We have a new phone system that was installed last week; prior to the install the phone lines were analog and directly connected to the PSTN. Now, everything goes through a VOIP system and we have to dial 8 to get an outside line. Is there a setting in the simulation codes that can automatically prefix outgoing calls with this number? It seems this would fit in SIM 66-01 somewhere, based on the research I was able to do on the Internet but I can't find anything to confirm it for any of the models we have (MX350 and AR-M237 and 257).
    Is there such a setting available?
    Is there a definitive model-specific list of the SIM 66-01 soft function codes available?
  • bdcrandall13
    • Sep 2010
    • 236
    I believe what you are looking for is actually in the key operator settings, not in simulation. I don't have an operation manual for those fax options but most machines have an option under key operator called fax settings or image send settings.
    • Silvertoast
      • Feb 2010
      • 270
      go into the menus and "image send settings" there is an option to add a prefix under the "send" settings
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1887
        FYI none of the manufacturers support fax over VOIP. There are things you can do to improve your chances of successful transmission. Turn off ECM, lower the scan resolution & lower modem speed.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
