pls help
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Misc] pls help
    hello all technician friends well l have a message Call your service represntative for scheduled maintenance ..pls l need rester this error message can any technician tell me ho can do it ? pls l am waiting
    BEST TECHNICIAN . NICE PEOPLE .
  • The Otrain
    • 54
    What model?
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      yes my friend the model is sharp AR122E N.....
      • DINGO
        • 661
        what simbol is light in the copier?
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          the simbol is small technician lighting and small round point ..in board penal of this machine you can red the mean of this simbol : call your service representative for scheduled maintenance ..also l published this pictures
          • Akitu
            Legendary Frost Spec Tech
            • Oct 2010
            • 2595
            Technician symbol means maintenance is required, means the maintenance counter has hit the pre-set limit. The small round point is probably a DV light, which would have come on roughly the same time as the service message.
            I have no idea what a 122E would be similar to, as it's not a model sold in my region, so I can't give accurate service information on what sims would clear it, though with most older Sharp machines, the maintenance clear code is 20-01 and the DV counter clear code is 42-01. Good luck!
            • DINGO
              • 661
              Hi
              that symbols are, technician symbol is , as akitu said said maintenance, you must reset it whith 20-01, and the small point is of corse the developer replace, and you reset them with with s.m. 24-06, this copier do not have 42-01.
              You must performe to the s.m 24-07, and the 24-08, means drum and counter reset.
              In this copiers the drum an dv life are 25k, and i thynk that yhou must replace the drum
              and strip cleaning.
              the sequency for imput the sm is:
              clear - densyti select - clear - densyti select - number sm - copy nkey.
              good look
