FYI for Jupiter 3 Machines
  • ZOOTECH
    Senior member of CRS
    • 3375
    To save you some dis-assembly time, if you have void areas running down the page in paper direction travel (prints or copies), check your foam filters on the DV unit before removing the left cover and LSU assembly. If they are not fully seated, it will block the laser beam.
    • 22997
    Re: FYI for Jupiter 3 Machines
    Now that's experience talking. =^..^=
    • ZOOTECH
      • 3375
      Yep, and it won't happen again without checking the filters.
      • Silvertoast
        • Feb 2010
        • 270
        very nice info. havent seen this yet but have seen the little white labels on process units and dv units peel up and block the laser. that cost me a couple of hours b4 i figured that out. lol
        • lky1978
          • Mar 2009
          • 482
          thanks for your info.
