arm355 with arfn6 add staple problem
+ More Options
Posts
  • krazykorean
    • Jun 2025
    Anyone come across this problem and solution???
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: arm355 with arfn6 add staple problem
    Most of the time when I see this issue, the staple cartridge isn't inserted 100% of the way.
    • krazykorean
      Thats what it seems like but what causes that? And any solution to this problem. It already had the staple unit replaced and the cartridge. It came back within 3 months
      • Akitu
        • Oct 2010
        • 2595
        Check the connectors going to the staple unit. It's been a while since I had to dig into one of these and I can't recall if it's a ribbon cable or other.
        • krazykorean
          Nope just the connectors. I have the fn opened up already
          • oldrn
            • 166
            I had this problem when using generic staples.
            • krazykorean
              The staples in this machine is from our company that orders from sharp. I think at least
              • bilyahn
                • Dec 2006
                • 1470
                Check the wiring harness to the stapler, I have had them rub through the insulation and cause random problems . Might be worth looking at. Had to splice a bit of wire to fix the problem.
                Good luck.
                Bil
                • Taha
                  Hi
                  I have the same error on my ar-m451n which shows "add staples" but i checked and i found that the staple cartridge is 70% full and the cartridge is inserted correctly , but i found that amazingly the home positioning sensor of the stapler unit and one spring is detached from it , i download and read the service guide of ar-fn6 finisher but i don't find how i can open the stapler unit and attach that part again . i will be happy if any of you could help me .
                  thanks a lot
                  home positioning sensor shows in attachment with number 20
                    • 22997
                    Originally posted by Taha
                    Hi
                    thanks a lot
                    Good luck with that. I've had a few of these staplers apart and they never seem to reassemble again. Too many very small parts. =^..^=
