MX-5500
  • swagreis
    • Jun 2008
    • 92
    MX-5500
    I have a trouble in this model that when I made b/w copy it is good but when made a color copy it gives also b/w copy low quality and also in the beginning of this trouble it sometimes gives color copy without cyan color
    when exciting simulation 50 -22 it gives error
    "Cyan phase error 121"
    Can anyone advise
    thanks
  • benalvarez
    • Feb 2015
    • 27
    Re: MX-5500
    I had this error just the other day
    sim 50-22 NG R on the magenta and NG R, it just takes a phillips screw driver, remove the waste toner box. The screws are under the development units on the model I was working on. These screws affect the alignment of the laser units (LSU), if the error reads NG R, you need to turn the phillips head screw to the right one click, then run sim 50-22 until it reads OK. Keep making the adjustment and running the sim 50-22 until it reads OK, don't be discouraged. You may need a flashlight to see into the area where the screw is. I hope this helps. The screw is slightly lower and to the left of the laser scan glass area.
    • swagreis
      • Jun 2008
      • 92
      Re: MX-5500
      U mean to readjust program 61-4
      • ohightower
        • Aug 2014
        • 33
        Re: MX-5500
        If 50-22 keeps failing you need a whole new transfer belt unit a spring or gear is broke in the other one and it wont allow you to calibrate the machine
        • spanky
          • Sep 2012
          • 468
          Re: MX-5500
          Go to 50-10 and set A to default value of 100.
          Go to 50-20 and set all of the colors to default value of 100.
          Run 50-22 and adjust accordingly.
          • swagreis
            • Jun 2008
            • 92
            Re: MX-5500
            I changed transfer belt unit but no change
            • benalvarez
              • Feb 2015
              • 27
              Re: MX-5500
              what does your error read (EXACTLY?)
              • swagreis
                • Jun 2008
                • 92
                Re: MX-5500
                I did all above but also the same!
                • swagreis
                  • Jun 2008
                  • 92
                  Re: MX-5500
                  Message exactly
                  Phase cyan error 121
                  • TreadHead55
                    • Apr 2015
                    • 6
                    Re: MX-5500
                    Your developer material or the unit is bad. Or if you are using off brand toner it is not dropping into the developer correctly. Only cure for that is to go back to Sharp toner.
