toshiba estudio 350 thermistor/logic problem
  • baldskull2014
    • Mar 2025
    [Error Code] toshiba estudio 350 thermistor/logic problem
    i have 3 machines go down all the same day same building with a c410 so i changed the thermistor on the first one and went go do 08-400 set to 0 and when i did the number 255 came up instead of the normal 1-9 or so and would not clear all three machines are doing this all are low meter and have the newest firmware any ideas thanks
  • gliderider
    • May 2015
    • 131
    Re: toshiba estudio 350 thermistor/logic problem
    HI: It's very unusual that all three copiers are having the same problem on the same day. Sounds like the common thread could be the voltage at the outlets is varying. I would meter all the outlets and check for proper voltage with a multi- meter. If that checks out then try reformatting the HDD.
    Andrew
    • baldskull2014
      thank you I thought it was very odd for this to happen i reinstalled the firmware and it made no difference my mind is kinda blown
      • Sriyanjan
        • Apr 2015
        • 79
        Check Low voltage power supply .
        Sent from my HTC Desire 820s dual sim using Tapatalk
