Been seeing a lot of the newer dev. units stripping gears, going over toned and having to be re-built, by a lot, I have done 4 so far and the other guy has done 1, this means all 4 gears, seals, and bushings, new developer, so far its been all black units and I think one cyan unit a while back.
These are the new type, ES 3055 ect...only thing I have found on exchange is a tech tip about using some form or oil or grease on the oil seals they call them.
Has any of my fellow techs ran across this, oh and on taking the unit apart to-rebuild, there is no sign of any kind of lube on the seals, so I put it back dry.
The gears have such fine teeth, it wont take much junk in them to wear them out.
Thanks ya'll
Thanks ya'll
