scan and e filing do not work
  • riyadh hossainbd
    • Dec 2015
    • 239
    hi, one of es 282 copier scan and e filing did not work , after initialize 08>665 code it works scan and e filing. Now one of es 455 is same I mean scan and e filing does not work but I did not find look like 08>665 code(M/SYS all clearing). Do you know which code can work on es455 copier to enable scan and e filing???
    note: there have print and scan kit
  • Sriyanjan
    • Apr 2015
    • 79
    Re: scan and e filing do not work
    top access > administration > setup > general > e-filing
    ๐Ÿ˜๐Ÿ˜Ž๐Ÿ˜
    Sent from my HTC Desire 820s dual sim using Tapatalk
    • riyadh hossainbd
      • Dec 2015
      • 239
      ๐Ÿ˜๐Ÿ˜Ž๐Ÿ˜
      still not work, this is a recondition product, Do u know someone how to initialize all 05 and o8 code of es455
      • Sriyanjan
        • Apr 2015
        • 79
        Perform HDD test (08-694) before initialize all .
        if you need to initialize all AD & AJ codes, use 9090 (printer all clear)
        Procedure:
        1. Set 08-201.
        2. Perform 08-9090.
        3. Perform 08-4581.
        4. Set 08-203 to "0".
        • riyadh hossainbd
          • Dec 2015
          • 239
          Procedure:
          1. Set 08-201.
          2. Perform 08-9090.
          3. Perform 08-4581.
          yes I tried these code but nothing helpful
          • Sriyanjan
            • Apr 2015
            • 79
            1.E filing function disabled or, 2.you can store to e filing & but cant access local folder via pc ?
            Pls explain
            • riyadh hossainbd
              • Dec 2015
              • 239
              Pls explain
              E filing function and scan function is disable though scan kit is installed
              • Ropariva
                • Mar 2016
                • 650
                Is it a separate scan and print dongle installed, or one print/scan dongle? Check that it is the correct one for the model. Is it showing as installed through TopAccess?
                • MUMMIM
                  • Jan 2008
                  • 125
                  Hi friend!
                  never set 08-665 with old copier ( e_xx0-xx2-xx3) , it is very dangerous for your machine.
                  you can use some code follow: 08-693,947,1001 and 690 (enter) , if non , you can update new firmware because some machine ( xx0) needn't update firmware but it can photo, but can't print
                  e455 is difference codes .
                  • riyadh hossainbd
                    • Dec 2015
                    • 239
                    Have any update suggestion??
                    or any hidden code??
