Toshiba e-Studio 2540c Toner issue
  • copyguy69
    • Feb 2016
    • 92
    I have a machine that says the toner is at 32 percent even if a new on is installed. It will run a while and then tell you the toner is low and to replace it, but you can feel the toner in the cartridge. Put new one in runs for a while and then does it again. I did the mylar update for the toner issue already. Any suggestions are welcome. Thanks in advance
    copyguy69
  • Blizzoo
    • Aug 2013
    • 592
    Re: Toshiba e-Studio 2540c Toner issue
    Hi,
    Just clean the board underneath the contact springs of the affected toner cartridge, check the motor and drive for smoothness and have a look at the augers where the toner from the bottle is fed to dev unit.
