Toshiba e-232 ADD PAPER n both trays Elevator is OK,
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Toshiba e-232 ADD PAPER n both trays Elevator is OK, updated firmware but no luck so far, exchanged actuators and sensors from working machine, still the same, elevator unit was tested with a working one, fuses in the LVPS are tested OK.
    running out of ideas, by the way the copier makes good copies from the bypass (only)
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Re: Toshiba e-232 ADD PAPER n both trays Elevator is OK,
    and both trays won't lift up (additional info).
      • 23008
      Test every sensor in 03 Mode.
      You may have a vertical path clutch problem. the sheet bypass doesn't use that clutch. These clutches cannot be disassembled, but you can work alcohol into them, and get it turning more freely. =^..^=
      • riyadh hossainbd
        • Dec 2015
        • 239
        Change lgc board and drawer entrance sensor or check cable
        • rapidocument
          Multibrands Tech
          • Jul 2012
          • 381
          Cable tie too tight broked wire/ (inner damaged), bad wiring from PCB to Elevator was the culprit
          Thanks to evereybody, specially to Hossain and BlackCat.
          Machine is up+running now.
            • 23008
            Congratulations on your success. =^..^=
