ES-755 DEVELOPER UNIT
  • ONAGA
    • 8
    [CQ] ES-755 DEVELOPER UNIT
    Is there any way to put a used developer unit with used developer into a machine and reset it up? Thank you for any help!!
  • Hansen88
    • 1066
    Re: ES-755 DEVELOPER UNIT
    It is not the best thing to do, but I have done it before in the past. If the quality looks good on it then run the 05-200 to lock it in where it is at. If it is too light I will manually add a little toner and get the quality where I want it and then run the 200 code. Like I said, it is not the best thing to do but I have got out of a jam by doing it before and it lasted a good time with no troubles.
    • ONAGA
      • 8
      That is what i just tried and it seems to be working for now. THANK YOU for the info.
      • ARMAN.MZ
        • Sep 2016
        • 100
        in mode 05-200
        device thinks devloper is new (buy new unit ) and change bios setting.
        if the developer used to another device and you put it in your mfp 755 you must use....
        6+ start On device
        and when device is redy
        1+ start
        after 3 min device stop and turn off
        torn on and use device
        Telegram ID : @armanmahzun
