disabale toner sensor in estudio 356-456
  • ARMAN.MZ
    • Sep 2016
    • 100
    hi friends
    anyone know how to disable sensor toner in toshiba 356-456
    in toshiba 355-455 to disable toner sensor
    08----499---0
    Telegram ID : @armanmahzun
    • 22997
    Re: disabale toner sensor in estudio 356-456
    Just curious. What benefit do you anticipate from disabling the toner sensor? The developing unit will quickly undertone until the copies and print go blank. Or are you trying to diagnose an "Add Toner condition? I don't see how it will help you. =^..^=
    • ARMAN.MZ
      • Sep 2016
      • 100
      When toner is low volume successive errors that harassment is
        • 22997
        Disabling the toner sensor will not help this situation. Your copies will go blank, and the machine will quickly become unusable.
        That is a solution of a sort ... just don't use it. =^..^=
        • ARMAN.MZ
          • Sep 2016
          • 100
          tnx for your help but still i need to disable toner sensor
          • sdrawkcab
            Confused & Bewildered
            • Jun 2009
            • 317
            YODA !
            Some days, it's just not worth chewing through the restraints
            • thienbangphoto
              tonner!
              • rapidocument
                Multibrands Tech
                • Jul 2012
                • 381
                disconnect it. (the machine will detect that).
                My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
                • ARMAN.MZ
                  • Sep 2016
                  • 100
                  disconnect what? sensor cable in lgc board?
                    • 22997
                    The power plug at the wall. =^..^=
                    • ARMAN.MZ
                      • Sep 2016
                      • 100
                      No One Knows?
                      • ARMAN.MZ
                        • Sep 2016
                        • 100
                        No body know?
                        • MUMMIM
                          • Jan 2008
                          • 125
                          In my country, we replace a "chip" of the cartridge, it is very cheap (0.5-0.7$/unit) so we don't need to know anything more
                          No body know?
                          • toshibaestudio
                            • Jun 2016
                            • 116
                            I wonder the chip on the cartridge can be re-use on other machine?
