Toshiba e-studio 255 streaks
  • lazymangr
    • Feb 2017
    • 115
    hello everyone. i need your help. customer got es255 around 130k prints and when it prints or copies it gives these lines. its about 1-2 pages every 10. sometimes it gives lines every time for like 10-15 pages then its ok. so since its on print too it has nothing to do with optical. any help?
    any admin please delete duplicate thread cause there is a bug and it shows it in print form for some reason and cant edit reply or delete it
  • lazymangr
    • Feb 2017
    • 115
    Re: Toshiba e-studio 255 streaks
    here is the attachment
      • 22932
      Re: Toshiba e-studio 255 streaks printtt
      Here's the thing: If you end your title in the word "Print" the thread is displayed in Printable View, which is nice if you're going to print it but not so nice if your want to respond to it, because all of the links have been removed. Noone can respond to a thread in Printable View.
      So if you'd like responses, all you have to do is end your title in any other word than "print". That should be easy, since there are ~150K other words you can choose. Or you can just misspell it like I did. That would make the number of choices nearly infinite, but not quite.
      • lazymangr
        • Feb 2017
        • 115
        thank you! i thought so! but couldnt even edit it
          • 22932
          Originally posted by lazymangr
          thank you! i thought so! but couldn't even edit it
          Correct! You'll have to get that right the first time. =^..^=
          • lazymangr
            • Feb 2017
            • 115
            bump?
            • thanhduong1986
              • Apr 2017
              • 13
              Developer has problems, instead
              • lazymangr
                • Feb 2017
                • 115
                its not developer. it happened on 1 more machine. toshiba official here in greece said is a problem to mobo and/or laser. changed mobo and still same. going to add some ferrites on laser and see. it looks like a electric noise
                  • 22932
                  mobo? =^..^=
                  • Blizzoo
                    • Aug 2013
                    • 594
                    mobo? =^..^=
                    MOtherBOard?
