Toshiba 1560 prints NO image please help!
  • runevel
    • Mar 2025
    Hi, I already change the powder, and still no image appears as it prints. Technical guys need service manual to fix. Can you help me? Thanks
  • Papo
    • Oct 2008
    • 36
    no image
    look at the transfer corona underneath drum it breaks clean inspect for arcing evidence.
    charge is your next suspect.
    • vale24
      • Sep 2008
      • 62
      T1560
      Does your expo lamp (scanner) is shining when you make a copy? if yes - you may have a problem with main charger or transfer charger (Papo wrote about this). if the problem is in main charger (corona) you have to take out the drum unit. Over the drum is main charger - check it (is it whole), clear it if there is a toner or something else. If the transfer and separation fibres are whole the problem you have to change corona holders (L and R)
      Good luck
      copier and printer service technician
      The perfect gift
      • runevel
        Thanks Papo & Vale24! I will check it this weekend.
        • esam ramadan
          • 199
          Chech 1- exposure lamp fuse
          2 - the ex lamp
          3 - it's board in the rareside
          4- wires of main charger - transfer
          • runevel
            Hello Mentors.
            I already check my unit 1560.
            1. lamp ok
            2. Wire to Charger was cut (so I fixed already)
            but when I start it the paper had a very light print like a shadow image. I already adjusted the contrast but same image. Can you advise me next? Thanks
            • vale24
              • Sep 2008
              • 62
              Wich wire did you change? (main, transfer, separation) and did you see well holder on the corona? Did you check holders for electrical breaks (it looks like white areas)? If you have another chargers (i meen whole body) you can check where is the problem, if you don't - look well for electrical breaks.
              And if you want you can change main charger voltage (05 - 38) and see wath happen.
              success
              The perfect gift
              • runevel
                THanks Vale24! I will check again. Just to inform you that the 'no image print' happen, when the 1560 was out of toner, thats why when I replaced it with new one, the 'no image print' still appears. I thought it was the toner only. until you advised me to check on the main chargers. THen a shadowy image appears. I guess just a little more adjustments huh. Ok sir I will check the main chargers. Thanks!
                • ss12
                  • Jul 2008
                  • 289
                  field tech
                  try checking the dev drive gears & the drive gear on the dev unit.there was a modification for this,the new gear was grey and slighty longer so it engaged with the drive gears properly
