UPDATE 455
  • ARMAN.MZ
    • Sep 2016
    • 100
    [Dead] UPDATE 455
    hi
    i should update toshiba 455
    but mfp's have not color dot
    i have frimwares red dot and yellow dot
    i should to use whitch frimware to update mfp?
    Telegram ID : @armanmahzun
    • 23008
    Re: UPDATE 455
    Simple answer: Do not check scanner firmware, and you can use either. It's the scanner that is different. =^..^=
    • arnh79
      • 468
      Re: UPDATE 455
      Also, e455 did not have yellow/red dot. That's the e456 series. Don't use the wrong f/w or you'll have a real mess on your hands.
      Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
      • thanhduong1986
        • Apr 2017
        • 13
        Re: UPDATE 455
        Originally posted by ARMAN.MZ
        hi
        frimwares yellow
        • riyadh hossainbd
          • Dec 2015
          • 239
          Re: UPDATE 455
          There are some Es 255/305/355/455 without red and yellow
          • didi2005
            • May 2011
            • 401
            Re: UPDATE 455
            When e455 series launched, it is using 3CCD where there is no stickers...
            Then after sometimes due to part shortage issue, they changed to 4CCD where red stickers is indicate using 3CCD while yellow stickers is indicate using 4CCD.
            If not mistaken, this issue only affect latter batch of e455 & early batch of e456 series.
            After that, all newer models starting from e457 series onward are using 4CCD.
            Anyhow, if want to play safe without screwing up the machine by updating wrong firmware, then just skip the scanner firmware as what blackcat mentioned.
            PS: Ignore above if u have jig on your hand
