e Studio 477S Fuser
    • 23008
    e Studio 477S Fuser
    I'm not sure how I did it but I ended up with a European 230vac single phase fuser. Then I got to thinking about the advice that I give everybody else. The only real difference is the lamps and the key.
    Sure enough, the 120v fuser lamps were 120v 400W/120v 800W (pink wires), and the 230v fuser lamps were 230v 400W/230v 800W (blue wires). Otherwise everything is the same. It was simple enough to swap out the lamps, and rotate the key 90 degrees.
    It was a simple enough adaptation, but I think next time I'll order the 120v fuser. =^..^=
    120-230 Fuser eS477S-2.jpg.
