Toshiba e studio 257, error F101-1!
  • 2bad4u
    • Oct 2017
    • 4
    [Dead] Toshiba e studio 257, error F101-1!
    Good Morning,
    I'm having troubles with a Toshiba e-studio 257. After a power surge the printer gets stuck on the error F101_1, i have the original install software T330ALL0W1281_USB.zip, from what i have found and read from the internet i believe this is a hard drive problem ( F101_1 is ADI HDD error, the root partition got corrupted unable to mount it).
    I tried the following:
    1. Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
    If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
    ===> The keys are ok.
    2. Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
    ===> I have formatted the disk and install the software and i still get F101_1.
    3.If F101_1 occurs with ADI-HDD or the error persists after performing step 3, perform step 3 after performing [4]+[C]+[POWER]→1. Revert factory initial status HDD.
    ===> I still get F101_1.
    IF problem come's back, you need to replace new HDD & update latest firmwares.
    What procedure is needed to replace the HDD on this model? Can i replace it with a normal smaller sata HDD 250GB, right now i have ADI HDD sata 500GB.
    Thanking you in advance and looking forward for your reply.
    King regards,
    Florin
  • Thayer
    • Dec 2017
    • 107
    Re: Toshiba e studio 257, error F101-1!
    You need a HDD, Toshiba wipe technology.
    G0-00732000 is part number.
    Replace hdd, perform clear & 3 then 3 format hdd
    Then clear & 3, 2 partition hdd
    Installed firmware, after firmware is done. Reboot in 08,and push firmware 9030 and initialize. This can take up to 20 minutes to complete.
    I airways calibrate the display after hdd replace, otherwise it will be a return call.
    Hope this helps
    • 2bad4u
      • Oct 2017
      • 4
      Could you please explain in detail the part "Replace hdd, perform clear & 3 then 3 format hdd Then clear & 3, 2 partition hdd".
      Sorry i but i don't understand.
      Also with the broken disk i tried to enter in [0] [8] + power after i reinstall the software. And it's not working i guess the disk is dead.
      The funny part is i don't get any error when i install the software or when i format the disk.
      • toshibaestudio
        • Jun 2016
        • 116
        If u tried format hdd & update firmware, but the problem come back, then definitely the hdd need to replace...
        U need ADI HDD (Wipe technology), follow your previous steps format hdd & update firmware, new firmware is auto initialize, or manual 08-9030, once everything is ok and machine is ready, remember to calibrate panel.
        Do pm me if u want the new ADI HDD. TQ
        • 2bad4u
          • Oct 2017
          • 4
          Sorry for the late response, i have managed to fix the printer by replacing the hdd and i have reinstalled the firmware, now everything is working great!
          Thank you for helping me!
          • taylormia
            Toshiba Printer Error Code C440
            Very nice topic you shared. Thank you for sharing with us.If you have any issue related Toshiba laptop then click here:
            • air_walkerr
              • Apr 2023
              • 1
              Hello,
              can somebody send me firmware for e-studio257?
              We have error f101.
              Thank you!
