Hey guys,
So, we went out to this machine and put a new Exit Sensor in it, didn't work. Then swapped the small harness that goes from the sensor to the connector on rear of the fuser... same thing. We ended up having to swap the fuser out but I'd like to get it running... just shows a permanent jam. Could there be a problem with the main fuser connector in some way...?? Weird...
OC
OC
