Estudio 3508A printing issue.
  • Zesti
    • Jun 2009
    • 308
    Hi,
    This estudio 3508A gives interesting issue. The machines configure smoothly on USb and network. But when send a print from computer via USB cable, the print is received in machine and nothing comes out. The log says print completed, data light also blinks while receiving data. On network the print goes out of PC but nothing happens on machines not in log nothing.
    Any idea what's going on, have checked all the settings in machine and all seems fine.
    • 22699
    Re: Estudio 3508A printing issue.
    Could it be something like an incorrect media type, or mismatched paper size? Are job account ID's set up?
      • 7874
      Check the Invalid queue located under the Print drop down box when you press the Print icon on the LCD panel.
      If your print jobs went here, you have not correctly configured the print driver.
      • Blizzoo
        • Aug 2013
        • 588
        Originally posted by Zesti
        Hi,
        If the machine is setup to receive only Hold jobs or Private/Hold jobs you will get a similar issue as you described. Look into Top Access in Printer section somewhere in the top list there is a drop down to choose the print behavior.
