e-Studio 3055c F101
  • photoguy42
    • Nov 2021
    • 2
    e-Studio 3055c F101
    Hello,
    I have a Toshiba e-Studio 3055c that is showing the F101 error. I have been tasked with getting it back up and running. I can access the HDD Assist Menu and other menus so it seems that the hard drive is functioning. I'm thinking its a firmware error and I could really use some help with the process. I dont want to brick the machine. I'm willing to compensate someone for their assistance and time. Any suggestions would be appreciated. Thanks!
  • Rusty.Harris
    • Jan 2021
    • 629
    Re: e-Studio 3055c F101
    Since you can access the hard drive menu in test mode, we can rule out an F101-0 error.
    There are F101-10 to 14. Which sub code is displayed?
    Originally posted by photoguy42
    Hello,
    • Blizzoo
      • Aug 2013
      • 608
      Check the S.M.A.R.T info of HDD, if value of C5 is more than 1 then replace the HDD. Error will get back shortly. You need Firmware as well
      • photoguy42
        • Nov 2021
        • 2
        Thank you for your help. I am getting an F101-1 error. Strangely, I was able to get into the File System Recovery Mode (5C) last week but not anymore. Any ideas?
        • Rusty.Harris
          • Jan 2021
          • 629
          Root partition mount error (HDD formatting fails.): The HDD cannot be connected (mounted) caused by damage to the areas in which the program is mainly stored.
          I would go into 3 Clear, format the HDD, and then go into 49 mode and reflash the machine.
          NOW, that being said, There is/was an issue with the LENGTH of the HDD cable being too long. Easy way to tell is by looking at the photo. If the connection has an "S" bend, then what happens is the bend is causing the electrical connections to pull away. Until I got some when the bulletin came out, I would just reverse the bend so the plug would push the contacts TOWARDS the connector instead of away from the connector.
