Toshiba MJ-1110 Finisher
  • Jenks
    • Oct 2021
    • 5
    I have a MJ-1110 Finisher when the pages come out of the middle exit tray the leading edge corner folds intermittently on the corner at the rear side of the finisher. It seems its not catching anything could it be worn paddles any help would be appreciated
    • 22999
    Re: Toshiba MJ-1110 Finisher
    Could it be flipping that corner much earlier in the process? Check the inner pre-registration mylar. If it's tucked under the roller you'll get flipped corners. =^..^=
