I don't work on Toshiba much, but found it interesting that the magenta and cyan developer seems to be spewing carrier out of it's housing, (rear gear area and left side chamber through the seam). I need to definitely replace carrier but was questioning to replace all four assemblies, or top DV covers as well.
Any feedback on this?
Is this a sign all 4 may be going bad?
Do you change all 4 units at this point?
Dev CLR only 30k each, with a drive count of 400k
