Estudio 257 Noise when tray lifts (Trys to lift tray to far)
  • Doug James
    • Jan 2012
    • 935
    [Misc] Estudio 257 Noise when tray lifts (Trys to lift tray to far)
    It seems that I have had this problem before but cannot figure out how I fixed it. I took the feed assembly out and it appears that all the actuators are working and going int the sensors correctly. The lift tray has no obstructions. The lift motor seems OK also. Not sure whats up. Havent seen one of these in awhile. Any help is very appreciated !!
    • 22881
    Re: Estudio 257 Noise when tray lifts (Trys to lift tray to far)
    The most likely cause is the sector gear on the back of the paper tray. They are known to split at the mounting screw, shear off the screw, or even have the screw back out a few turns. Also the metal posts that the other gears sit on can bend off-90 degrees and the gears disengage. When you install the new gear use a removeable version of Loctite on the screw threads (I use enamel nail polish for this purpose). The part number for the gear is 6LJ11610000:
    Results for 6LJ11610000
    Hopefully the one in the picture is just an old picture of the old style gear. The new style gear is black.
    There are other possible causes, but this is the most likely. =^..^=
    • Doug James
      • Jan 2012
      • 935
      Got it ordered. I always very much appreciate your help !!! It's above and beyond THANKS SO MUCH !!
