281c close front door
  • razzer
    • 34
    hi all;got a 281c that powers up and goes to ready and copies ok,yet if you open the front door or fuser cover it won't go back to ready after you close it.it just sits at "close front cover" on the display.any ideas?thanks tried a different switch,no luck.
  • atudorica
    • Oct 2007
    • 79
    right side iner cover
    you may adjust the hight of the door actuator
    front cover and side door both push the same sensor
    only the side door is adjustable
    • razzer
      • 34
      yea we overrode the actuator by pushing in the piece at the center of the switch that it activates when both doors are closed.also tried a different switch.
      • atudorica
        • Oct 2007
        • 79
        what about the microswitch pushed by front cover?
        on top of the double pushed sensor
        • Harry
          • 228
          i have make a ryplay at the other tread
          have a nice day
          • franc99
            I see a trouble like this a time ago. When power on the copier i had this message Close front cover. Test the switch is ok. I had fixed the cable of the cover switch in correct position under case of toner and my copier work ok since this (many month). I suppose induction in switch cable.
            If you had work in this portion of the copier, check if you have replace the cable in the good position.
            Good luck
