Re: Toshiba 3015AC color developer
Toshibas are very forgiving in this aspect.
We have used xx55 DV in the xx05 and xx15 and vice versa, not something you want to leave running for an extended period but, it will "get you out the door".
You can also swap toner carts between these models by swapping the toner chips and cutting of the tab on the front of the cart. Keep in mind toner % will be whatever is left on the chip you took it from. Again, not something to be left for an extended period of time.
