Re: A great Toshiba YouTube channel
Toshiba not recognizing toner
Toshiba not recognizing toner - YouTube
Anything on a EAB0 error in saddle stitch , paper all mangled up ?Leave a comment:
Ownership is clear the product behind it is something to consider.Leave a comment:
Toshiba Tec, Xerox and Sharp have partnered with Lexmark to relabel their A4 machines while putting their own unique twists on the product they offer for distribution. Konica Minolta did the same for awhile.
It is the way of the future. In approx two years, Ricoh and Toshiba Tec will offer the same A3 print engines.Leave a comment:
.... the Xerox C415 is very similar to the Toshiba e409CS. Both are a relabelled Lexmark with modified LCD panels. The Xerox has an extensive app gallery. The Toshiba has eBridge Global print.
How to replace the (black only) imaging units on your Xerox machine: New C410, C415
How to replace the (black only) imaging units on your Xerox machine: New C410, C415 - YouTubeLeave a comment:
How to replace the (black only) imaging units on your Xerox machine: New C410, C415 - YouTubeLast edited by SalesServiceGuy; 02-09-2024, 08:41 PM.Leave a comment:
The Xerox C415 is a relabelled Lexmark and very similar to the Toshiba e409CS.
A good video on replacing the Doc Feeder feed rollers.
How to replace the document feed roller kit on your Xerox machine: New C410, C415
How to replace the document feed roller kit on your Xerox machine: New C410, C415 - YouTubeLeave a comment:
Copier OEMs like Xerox, Toshiba and Sharp relabelling other OEM's products is common.
Lexmark has not been directly accused of violating any export laws in any country.Leave a comment:
Are you proud with that, after all Lexmark was bought by Chinese and now you're telling us Toshiba (Japan company) is making Chinese clones. That's quite reverse engineering and I trust them zero.Leave a comment:
The new Toshiba e409CS A4 desktop colour laser MFP is very similar to the Lexmark CX635awde.
C2335/CS531/CS632/CS639/CX532/CX635/XC2335—Replacing the imaging kit - YouTubeLeave a comment:
Rotate Sort
Rotate Sort - YouTube
A great video on dealing with torn originals going through the Doc Feeder and how to quickly create one touch butons using the Home+ button.Leave a comment:
I used this video today to clear out a jam caused by a staple in the e2555c Doc feeder using thick paper.
Jamming in the Document Feeder
Jamming in the Document Feeder - YouTubeLeave a comment:
... another Toshiba copier repair channel that I found.
... so this could be a big money saver, because CMY Developer is so expensive?
It does cost some extra time.
In Canada, e3505AC K Developer cost $160.53 CMY Developer cost $686.61 each from the OEM.
On the e3515AC and e3525AC, the Developer cost even more.
By several hundred, do you mean 200 to 300 skyshots with max toner on the page?Leave a comment:
