Airprint on es287cs.
+ More Options
Posts
  • eddies
    • Oct 2023
    • 4
    [Misc] Airprint on es287cs.
    Hello!
    I have a client that has a eStudio 287cs that they've had for about 8 years. And as we know, it's a discontinued model and hasn't been under maintainence for a few years. But it is still a working machine in good shape. We are trying to setup Airprint on it so the owner can print to it from his iPad. Toshiba lists the 287cs as having supported Airprint but the settings shown in the service manual to enable it aren't there on this particular machine. So I'm assuming Airprint support was added by Toshiba or Okidata at some point after the firmware currently on this machine, which is T280HD0W2363 dated 2/18/2016.
    Has anyone gotten Airprint working on an es 287cs? And if that is the case, have a firmware version that allows turning Airprint on?
    I appreciate the input.
    Thanks!
    Eddie
  • arnh79
    • 467
    Re: Airprint on es287cs.
    For that model, there was a specific plugin you had to install, the same way you would for FW. If that module wasn't installed then I don't think even loading the latest FW version would enable it. We don't service that model now, so I don't have that module anymore.
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
