Toshiba 7508
  • tsbservice
    replied
    Re: Toshiba 7508
    Originally posted by Joe Foe from Buffalo
    Sad seems like this tech page is going down the tubes with helping fellow technicians since I've used it last. 🖖🏻
    Actually it isn't and still providing very valuable information and help for us technicians.
    Just my opinion.
  • Joe Foe from Buffalo
    replied
    Re: Toshiba 7508
    replied
    Re: Toshiba 7508
    The e7508A was introduced in Sept 2016 and discontinued in March 2018.
    This copier needs to be upgraded to a e7529A to reduce your service calls.
    replied
    Re: Toshiba 7508
    So there's no solution. Now I get it.
    I usually try to address questions as they come up, and there weren't any questions in your post. I don't mind a little snark in the response, but I think I'll just let this one go by, thanks. Good luck. =^..^=
    replied
    Re: Toshiba 7508
    Thank you for non constructive response. Hopefully you feel better doing so. FYI I've been a technician that works on anything from a-z that uses paper since 1980... That yes sometimes I ask for help. This machine is in a prison in the population. Can't take anything more than a screwdriver 99% of the time an being watched talked to all of the time by prisoners an guards want me out of the machine, area asap
    ... perhaps you have been in the industry for too long because when your first response is to sh*t on responders, this does not make one want to reply.
    I have worked on copiers in prisons and I know the process is onerous. We eventually got rid of this kind of client for greener pastures.
    Why a copier is accessible to any prison population is a big no no by itself. There are lots of sharp metal objects and glass inside a copier. The copier should be in a secure Admin area. I would decline all service until the copier is moved into a safe work area for yourself.
    replied
    Re: Toshiba 7508
    It's a negative, that's interesting. Thanks for sharing. How much confidence do you have in that solution? =^..^=
    replied
    Re: Toshiba 7508
    started a topic [Electrical] Toshiba 7508
    Toshiba 7508
    Toshiba 7508 black and white machine. Background like it's losing bias. Technician performing preventive maintenance replaced drum unit charge units development unit developer. Possible cause ITB Assembly electrical spring connection near the drum unit connection. Randomly can pull the drum ITB assembly out of machine push it back in it'll go away for a couple hundred copies. Click on the link for sample of image
    Shared album - Joe Foe from Buffalo - Google Photos
