E010 In Toshiba 350
  • mitsubee
    replied
    When you ON the machine it straight away e010 or u copy half way till the fuser part then e030? if straight away pop up happened then the exit sensor lever is broken..is not then the exit sensor is faulty or dirty.
  • BoBa
    replied
    replace exit sensor
  • mdanaj
    Guest replied
    Paper transport jam
    [E010] Leading edge of paper not reaching the exit sensor
    Open the jam access cover. Is there any paper on the transport path?
    YES
    �� Remove the paper.
    NO
    Is the exit sensor working? (Perform the input check in the test mode: 03-[FAX]ON/[2]/[B])
    NO
    �� 1) Check if the connector of the exit sensor is disconnected.
    2) Check if the connector CN302 on the LGC board is disconnected.
    3) Check if the connector pins are disconnected and the harnesses are open
    circuited.
    4) Check if the conductor pattern on the LGC board is short circuited or open
    circuited.
    5) Replace the exit sensor.
    6) Replace the LGC board.
    YES
    Is the registration clutch working? (Perform the output check in the test mode: 03-108/158)
    NO
    �� 1) Check if the connector of the registration clutch is disconnected.
    2) Check if the connector CN318 on the LGC board is disconnected.
    circuited.
    circuited.
    5) Replace the registration clutch.
    YES
    Check the registration roller. Replace it if it is worn out.
  • nasrullahbutt
    started a topic E010 In Toshiba 350
    E010 In Toshiba 350
    hi every one plase tell me E010 Code in Toshiba 350
    wating for your kind responce
    nasrullah butt
